Best Intercooler?
#46
Originally posted by silverEVO8
Good info Joe
Thanks for posting it. I wonder how one could inject water (or perhaps something like toluene) just when needed? I guess the AEM ems has several outputs and inputs and I could perhaps program it to spray at full throttle.... I also wonder if the spraying could be done in the IC outlet pipe? Or perhaps it must be done at the intake manifold?. I was thinking that it would be extremely efficient and very cool to inject an octane improver at just the right time. Toluene comes to mind. It would seem that a metered amount shot into the IC pipes just at full throttle woul be phenomenal. just think, getting 96-98 or higher octane only when needed! the rest of the time (cruising, part throttle under light loads, etc.) you'd run on 93 octane pump gas! One gallon of toluene could conceivably last for 3 or 4 tankfulls of fuel.....
Good info Joe
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Toluene has its place, but not here, IMO. There's a lot of discussion about this over at the other forum I mentioned where they go into mixing water with methanol, ethanol, toluene, xylene, etc. I'm not that cool, I'm sticking with washer fluid.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Happy spraying,
Joe
#47
Originally posted by 4G63>OOOO
You might want to research this a bit more. A properly tuned WI system is as good or better than any intercooler you will design, period. Just like a properly tuned motor will yield power, so will a proper WI system.
Check out:
Water injection forum (very informative)
Water injection FAQ
With WI, you can tune higher A/F ratios without worrying about detonation, to a degree. (12.5:1 instead of 11.5:1 or whatever).
Happy spraying!
Regards,
Joe
Check out:
Water injection FAQ
Happy spraying!
Regards,
Joe
And If someone designed an intercooler that is produce COLD air that doesnt pre-ignite, it is IMHO better than a WI system because it doesnt introduce excessive water in the system.
#49
Angle Of Mercy, you are the only person that I have ever herd of that actually like the UKs crap weather, hehe. From what I have gathered, detonation is not too much of a problem on the Evo. It has a much better head design and inherently less detonation then the likes of the Cosworth engines that most are used to (over here). Most of the guys with them that wont to run 2 bar have to run around 7 to 1 comp ratios just to stop the things from blowing up (when the turbo finally kicks in). I just think that with water injection it enables you to run a bit hotter than without, just my opinion. I do agree that if your engine is to hot, then for the road, you should back it off. But it would be nice to turn the boost up (and advance the ignition) and the water on when you hit the race tracks.
#50
Originally posted by Angel Of Mercy
Read my post.. i said, the concept is good.. i also said.. it works... BUT, I dont like the idea of water in my engine... i have no arguments with you or anyone else that you can produce more power... however, my view/preference, is that I DONT LIKE WATER in my engine... especially excessive amounts...
#51
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
Also, from what I read and hear, my case is not unique
![Roll Eyes (Sarcastic)](https://www.evolutionm.net/forums/images/smilies/rolleyes.gif)
400whp, 9000, ams, evo, evolutionm, good, innercooler, intercooler, intercoolers, pipes, precision, saab
