What timing belt and water pump for evo9??
So I thought id get a 2014 updated thread since the others are pretty outdated.
What kind of timing belt and water pump is suggested for an evo 9
Timing belt- Gates or GMB?
Water pump- OEM or Gates?
I'm running a 2.3l stroker w/ a big turbo so what is the best way to go in terms of both?
Thanks in advance.
Thanks in advance.
Doesn't really matter if you use Gates or OEM water pump / timing belt. They both work fine. I've seen people saying that the kevlar belts will last longer, but when it comes to timing belts, you should have regular maintenance no matter what.
As for the water pump, again both work perfectly. People seem to choose the Gates over the OEM because it's top quality for a cheaper price.
for the timing belt, I was looking into the one map has but other shops say its only for evo 8/dsm whereas map says its for evo 8/9/dsm.
http://www.maperformance.com/gates-4...t-evo-dsm.html
wazmunstr
149
Oct 9, 2019 02:21 PM
orion4096
35
Jan 25, 2016 03:37 PM
EvO-LOui
Feb 18, 2015 10:38 AM
RussellM
20
Dec 14, 2014 07:57 PM
