Need help, refreshed head, oil on back of valve, is this a bad valve seal?
I took a close look at my valves from my refreshed head. The head is mounted on the motor outside of the car and has not been run. One of the valves seems to be wet on the back side. I cant see a trail coming down the valve from guide. The valve seals were supposed to have been replaced when the head work was done. The motor has only had assembly lube in it so far. Take a look and tell me what y'all think.
It's probably just some residue or spatter left over from assembly. I wouldn't worry about it.
Yes.
If you haven't even put oil in the motor, or run the motor, there is now way for their to be oil coming through the valve seal.
I think I'm going to dry the valve portion in the port, remove the VC, and drop some oil right onto the valve stem end to see if it leaks passed the seal.
dsm nexus
27
Sep 3, 2016 02:05 PM
FS[MidWest]: Oem and aftermarket parts, will trade for pizza..
dsm nexus
52
Jan 5, 2016 09:26 AM
dsm nexus
22
Sep 19, 2014 06:51 AM
dsm nexus
17
Sep 7, 2014 09:46 PM
