Possible head gasket leak or head lifting?
Old May 6, 2014 | 09:10 PM
RedLanEVO's Avatar
The other day, I got on it a little bit in 4th gear and it blew my lower radiator hose off. I have a 2.3l with a hta3586r turbo kit. I've had frost plugs blow out from the head lifting before so I'm hoping its not another situation like that. I just want input from you guys. Maybe there are things I can check out that can verify the issue, maybe not. I have not tried wot again since the hose blew off.
I filled it up with water and have been driving it for the past 2 days and the fluid seems good. It hasn't gone down and the plugs look good.
Any input or advice would be appreciated.
Old May 7, 2014 | 03:57 AM
way2qik's Avatar
That is almost certainly caused from combustion getting into the cooling system. And, yes, that is usually from the head lifting a bit under boost. It doesn't sound like you blew the headgasket, but I can't say that for certain. One thing I would do is check the torque on the headstuds/bolts. Do you know if you have studs or bolts? And, do you know what torque they ought to be?
Old May 7, 2014 | 06:31 AM
RedLanEVO's Avatar
I have l19 studs torqued to 95lbs
Old May 7, 2014 | 10:24 AM
way2qik's Avatar
I would re check them. See if they are still at that number. I would be willing to bet you have a couple that have loosened up some. Or, a couple of them have stretched just enough to allow the head to lift just a tad bit. How old are the head studs? Either that or you have a blown headgasket.
Old May 7, 2014 | 12:36 PM
slowsrt4:('s Avatar
you would have to be making a ton of power to lift the head with properly installed L19s, were you at a low MPH in 4th gear when u got on it? if so, this would cause the turbo to spin a huge volume of air which could lift your head.
BrandonIX
15
Jun 12, 2016 09:17 PM
ridenrunwv
Jun 25, 2015 11:14 AM
ridenrunwv
Jun 10, 2015 11:41 AM
holiday63
Jul 27, 2010 07:53 PM
David Buschur
93
Jun 18, 2008 10:41 AM
Quick Reply: Possible head gasket leak or head lifting?
