block surface prep question
Rebuilding the head. Its at the machine shop. And im in the process of cleaning up the block surface and would like some input on how to proceed without screwing up the surface. Here is a pic of what it looks like now, still need to clean 2 pistons. My concern is the corrosion around each cylinder. I've cleaned with a razor and scotch brite w brake cleaner so far. I've got a buddy telling me to hit it with sand paper....not sure about that.
I've also attached a pic of the old head gasket.
Run it? Go a little further with scotch brite? Hit it with some sandpaper on a block? I'm out of mind and it'll never seal unless I pull it and deck it?
use 400 grit wet n dry on a 1/8 inch aluminum plate for flatness. check the plate first. ONLY take the corrosion off no more. Make sure to plug the piston holes so nothing gets in at all.wipe bores with micro fiber towels and oil, repeat cleaning once more.
lol. Ive stared at it a little more and that's about it. My neighbor is coming over tonight to give me a 2nd opinion. Im just really hesitant to hit with sand paper and don't want to use the scotch brite anymore. Its almost not enough to feel. And Ive got others saying to just run it. I just don't want to do it again and don't want to kill it trying too hard to clean it. No clue where to get a machined plate of aluminum. Got regular sanding blocks, but it doesn't sound like that is the right way to go.
I'll have the head back this weekend, so I plan to do everything I can (including this) this week.
Copper coat both sides of the HG, install and ship it...
roni4g63
Feb 12, 2016 08:26 AM
David Buschur
228
Feb 10, 2013 11:06 PM
TommiM
13
Jun 12, 2011 10:59 PM
