Need another 70whp.
Need another 70whp.
Hi guys,
the car is an 05 evo 9 and current mods are:
-full tbe
-greddy 264/264 cams
-fuel pressure regulator
-apexi afc neo
On dynojet its producing 328.79whp and 303 ft lbs wtq at 1.5 bar on Ron97 pump gas.
The car is daily driven and goes to the track occasionally. I need another 70whp or to hit my 400whp goal. So what would be the most sensible and economical way to get that extra 70whp?
If i upgrade the turbo, I'm looking at the gtx3071r stock location. is this the best turbo for the job if spool must be as early as stock?
note: Where i live, FP turbos and E85 are not available or sold. (at the same time upgrading the injectors and fuel pump).
another candidate and relatively cheaper is MHI td06 20g, but would it spool quick enough?
How about the electronic bits, is the afc neo adequate? or i need a ecu flash or standalone?
Please do comment and share your experiences and help me to get another 70 ish wild horses. Im new to force induction and evo platform. :thumb up:
-full tbe
-apexi afc neo
05 is a Evo 8. If you wanna make some better power get some bigger cams for sure. Go ahead and upgrade the springs and retainers in the head and throw in some S2,s, a good intake, intake manifold...maybe a rev2, or rev3. Port the exhaust manifold and get a good upgraded 02 housing. Alot of the guys that are making over 400 hp on the stock 8 turbo are running Ethanol.
Thanks for the quick reply bro
my car is a jdm evo 9. We don't have ethanol fuel here. Just pump gas.
like i mentioned i want to stick to pump gas, Ron97. Increasing the usable rpm is one possible option, that i didnt really thought of.
So by changing the valve springs and retainers and also fitting higher duration cams ill get
More hp on top(on pump gas)
but ill sacrifice low end power? and idle won't be smooth?
The car is daily driven around town, would this mod take away the drivability?
Get kelford they make more power period. Vendors have marketed gsc because they have better profit margin but arent bad cams kelford are better though. However if its gsc r2 but those beed retainer and spring...those cams aee nice
You are going to need methanol injection and lower intercooler pipe.
You also might want to crush an oem e9 bov.
Fmic ets/buschur/muse will allow a littlr more timing
Preload waste gate actuator more too
I actually had Mivec Kelford 272's and sold them to another Evom member about 2 years ago, i bought the GSC S2's not only did i pick up a good amount of midrange power and torque i picked up about 500 RPMs more usable powerband on the top end and made more power.
I do agree tho in regard to a intercooler upgrade i didnt even think about that at the time.
appreciate all the replies.. {thumb up}
it seems that i don't really need to upgrade my evo 9 turbo to get another 70whp, or at least hitting near 400whp.
i guess with a more aggressive cams losing a bit of torque down under is not that bad since adding a bigger turbo would create a bit more lag too.
cost wise, a pair of cams are cheaper, but do i need to upgrade my springs/retainers for the kelford 272s( 11mm lift) and what is the max safe rpm on stock internals?
