Replacing valve seals on car - Easy!
from factory at full lift on stock cams there is like 1.2 mm between the top of seal and bottom of retainer. ad aftermarket cams and it can be just .2mm. thats just .008 clearance. float is when cam follower is lifting off the cam lobe. the bottom of retainer hits the seal like a bump stop.
with aftermarket retainer the clearance is opened back up and the bump stop effect is lost. the stock retainers are aluminum and made pretty thick.
One thing odd though is I believe my retainers are steel as I used a magnet to place them back on the valve stems.
Are you sure OEM retainers are aluminum? If so that would mean the previous owner must of swapped retainers.
Thank you for that bit of education and that makes perfect sense. Since I am still on stock springs with Kelford cams maybe I'll reduce redline to 7k.
[FS] Evo 8 Motor Partout
Jeepyedo
Sep 25, 2016 02:10 PM
FS[Pacific NW]: Te37 18x10.5+15 pic heavy pdx asking $2850 text 6268236386
06h
For Sale - Wheels / Tires
Apr 26, 2016 11:58 PM
06h
Apr 26, 2016 08:52 PM
Jeepyedo
12
Apr 5, 2016 06:07 AM
FS[Pacific NW]: Volk Racing TE37 18x9.5 +35 squared White Oregon
06h
Jun 27, 2015 12:53 PM
