6Speed on evo ix mr failing
After a high speed run I had a rough shift in 4th and after the run I was usin 4th just fine after the run and it was still strong for like 60seconds but downshifted to 3rd at 1800rpm cause of speed limit and a tight turn then, in 3rd from 1800 i accelerate gently and shift smoothly into 4th at 3000rpms and it immediately makes a loud *** clanking noise in 4th but it still works and accelerates while makin the clanking noise and now it grinds when u shift into 4th (guessing synchro failure) and still clanks like it's skipping a tooth or somethin but the gear still works
It's an evo IX Mr with a 2.0stage 1 evo dynamics build (15k on new engine), stock trans has 88k miles on it and has been getting 375whp 345tq thrown at it for 73k miles and this is my first prob with the 6 speed on the IX MR
I have a vid I'll stick to this of the sound.
Please people comment and suggest what should be done it would be greatly appreciated
Thanks,
ConnorEvoIX.
Thanks,
ConnorEvoIX.
I'm surprised you made it that far on that transmission. I have 50k on my IX MR, and 6th gear is very hard to get in and out of gear. I have a spare transmission that was rebuilt that I'm installing soon. I recommend that everyone that owns an Evo with a 6spd transmission always have a spare transmission lying around. And the reason that I won't convert mine to a 5 speed is because as rare as the IX MR's are becoming, I want to keep it as original as possible.
1 Post
what about the evo 8 MRs, are they rare? I like how smooth my 6 speed trans is, but it is so damn weak. Shep is selling upgraded gearsets, should make the trans worth-while
Thanks,
ConnorEvoIX.
Thanks,
ConnorEvoIX.
what oil u using in the gear box?
