416 walboro need new regulator?
Most quiet external inline fuel pump?
Is there a fuel pump similar to the walboro 255 (gs392) that is quieter? Mine is dying on my ams surge tank but it doesn't look like a 341 or a 342. I dont want to get a 400 because i'd need a fp regulator.... External pump of course.
The 416 and 450 are the same pump, at least if we are referring to the E85 version. Everyone should be running the E85 version. Its got much better flow rate than the gasoline version.
Bottom line is do not hardwire the 416/450. Setup up a pressure switch-activated direct power feed from the battery and splice (not cut) into the factory power at the plug to the pump. Splice into the ground wire as well and run an additional ground.
yup. The pump will run on stock wiring for OEM low voltage and for an intermediate time on OEM full voltage. When the Hobbs switch activates, it will supplement the OEM full voltage. Its like a three stage voltage system rather than a two stage system.
VIIIdriver
Apr 19, 2013 06:44 PM
TTP Engineering
Dec 2, 2009 05:53 PM
Aman
Jun 16, 2009 05:27 AM
DynoFlash
75
Jan 10, 2008 06:10 AM
