Shaft Play in BB turbos
There is not much information out there comparing shaft play from a BB turbo to a JB turbo. I'm curious, will a BB turbo have more accepted shaft play than a journal bearing turbo?
I have a BB turbo that will remain unmentioned for now at least, it is one of the top performing turbos in this community. It has no issues as of now, although it does seem to have quite a bit of side to side and in and out shaft play. The turbo makes boost and doesnt smoke or anything weird so I will continue to run it till I notice something bad.
I only have about 60 miles on the turbo and I have not even been tuned so I have yet to make over 15psi. When the turbo was new out of the box, I made sure to prime the motor and pump the oil into the turbo prior to starting up the motor.
My question is do your BB turbos have play and if so is it normal?
yes they have play. would be alarming to some. but is normal. play in bb turbo is not as critical as journal bearing. journal bearing relies on a oil film layer for the shaft bearing to ride on. if that oil fill gets larger the film offers less support . with bb the bearings offer same support no matter what the play is. best to monitor closely every new turbo to be sure any play is not progressively getting worse.
I never let anyone play with my wheel as I am OCD and paranoid of someone being to rough on it, but I decided to randomly check for myself and I was shocked.
I still havent turned in my warranty card yet as I am not really driving the car at all (stilll revising the build)
evoixmr1818
25
Apr 17, 2010 05:36 AM
Speed Element
58
Apr 18, 2006 05:36 PM
