03 Evo cv shaft popping out.
I have a 03 gsr, just replaced the front passenger cv shaft and seal. The axle locks in strong and bolts up tight 160ft/lbs no issues. When I drive it down the road it pops out on left turns and leaks gear oil. The retainer clip is strong and its very difficult to remove by hand or crowbar once pressed back in. Its also making some knocking noise on left turns. I'm stumped the only thing I can think is wrong is the axle is not OEM and is from advanced auto parts but looks like it fits well and is not the issue.
I'm experiencing this issue now. Just installed dss stage 1 axle. Pulled out of the garage today and all my tcase fluid was on the floor. Upon inspection I noticed fluid from the passenger side axle so I pulled on it and it slid right out. What would cause this. I have 2k miles on them already with no issues
I have the same issue currently on my passenger side as well. Ive replaced the axle seal 3 times thinking I installed it wrong when I replaced my axle but then i noticed you could pop my axle out of tease with ease. I replaced the C clip, and the axle seal it is still leaking, its a brand new axle (advanced auto). Even with the brand new C clip i installed the axle immediately you can pull the axle off with no issue and the C clip with be completely smushed (same diameter as the spindle coming from tease) anyone have a clue? maybe its axle?
Go to Advance Auto (I'm just picking on them for no good reason) and chances are you will receive the wrong axle. Before you swap parts check carefully that they are the same.
Anarchy99
11
Mar 7, 2012 12:17 PM
BlackonBlack2
Feb 26, 2012 05:58 PM
okevolutionVIII
33
Oct 30, 2011 08:05 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
mrblob20
Dec 26, 2006 07:47 PM
