ETS 4inch intercooler pressure drop
So i just put on my 4 inch ets intercooler and went from 25 psi dropping to 21. to 21 psi dropping to 16 psi. Can i turn the boost back up to where it was without tuning it?
Yes had stock intercooler before. It basically dropped 5 psi from what I can tell. I have a manual boost controller
Did you only swap out the IC and not change anything else, i.e. IC piping? If you only changed the IC then I seriously doubt you that you have a BL. If you had not connected and securely fasrened the IC couplers properly then it would be obvious....big time.
Just raise your boost pressure back up 4# via your MBC, man. Also, get a real boost gauge. This is EvoM not the Mickey Mouse Club.
There could be some pressure drop. You should do a boost leak test. Its a good idea to do one whenever the charge pipes, or anything that see boost pressure, is taken apart..
03redtype-s
Oct 17, 2015 06:02 PM
way2qik
94
May 21, 2012 07:18 PM
06redrocket
Jun 29, 2010 11:04 PM
strtrcng426
Dec 7, 2009 11:00 AM
HB Speed
Sep 1, 2009 03:59 PM
