Fuel Pressure Dropping - New Pump, Reg. etc.
Having a problem with an Evo 3. It is currently making about 415 hp on E50/E60. It was running lean up top so we rewired the walbro 255 and that helped things a bit. However when we pushed it harder it began to lean out up top again.
We then replaced the walbro with one of the ethanol compatible walbro 420 pumps along with an AEM fuel regulator. We did not drill the siphon in the tank so it overruns the regulator, minimum fuel pressure at idle is 50 psi with the vac. line disconnected.
Under boost (30 psi) the fuel pressure rises to 80 psi but quickly drops back to 60 psi. However if you run the pump manually and wind in the regulator the pressure can be carried to above 100 psi (maximum on the gauge).
The vac. line to the reg. is fine and the battery voltage is not dropping off as rpm rises.
I am wondering now if the stock fuel lines/fuel filter are a restriction at this point and that due to the restriction the pump is unable to deliver enough fuel flow to maintain the pressure when the fuel demand from the engine gets higher. However, the car is not really making crazy power so I am not so sure about that one.
Anyone experience anything like this?
Inadequate power or ground wiring would cause the issue regardless of pump used. If you've checked that voltage across the pump terminals does not suffer under high power demand, then it points to the feed.
This turned out to be the problem. The original pump was rewired but it seems that these pumps are more sensitive to voltage. Without proper wiring they don't seem to be any better than a 255. Basically you have to put in the proper infrastructure to be able to feed its appetite for electricity.
FS[Northeast]: Fuel lab Fuel pressure reg. W/line & fuel rail fitting.
06EvoIXmr07
Jun 20, 2016 08:01 PM
Carloverx
14
Dec 22, 2011 01:00 PM
TKEVO
Sep 1, 2010 03:41 PM
superscout03
Apr 29, 2008 04:11 PM
