Oil Pan Cleanup
Old Dec 28, 2014 | 12:05 PM
ReivaXVrai2's Avatar
Oil Pan Cleanup
I am doing a rebuild on my engine and I want to completely clean my oil pan to get rid of any contaminants and the old oil. I don't have access to a hot tank, and I need to clean it in my own home. What is the best way to go about it?
Old Dec 28, 2014 | 12:10 PM
todd6027's Avatar
dishwasher
Old Dec 28, 2014 | 12:16 PM
How do I avoid rusting it in the process?
Old Dec 28, 2014 | 07:19 PM
evo9dud's Avatar
spray it with brake cleaner, quick and easy and It shouldn't hurt factory coating
Old Dec 28, 2014 | 07:52 PM
So, spraying brake cleaner on it after its dry won't hurt it or leave behind anything that could harm my engine?
Old Dec 28, 2014 | 07:59 PM
BlackHawk_Tsi's Avatar
Break cleaner does leave behind a residue that will prevent rust but I don't know what that chemical is. To be safe just wash however you want, and rub it down with new motor oil.
Old Dec 28, 2014 | 10:11 PM
evo7_8u's Avatar
Lot's of brake clean.
Old Dec 28, 2014 | 10:19 PM
twabtoxer's Avatar
I have used gasoline with a scrub brush, then some break cleaner
Old Dec 28, 2014 | 10:34 PM
xXANCHORMONXx's Avatar
Bring it to a machine shop and throw it in a parts washer
Old Dec 29, 2014 | 03:01 PM
oldwheelieguy's Avatar
Brake clean
Old Dec 30, 2014 | 05:44 AM
Will do, thank you!
Old Dec 31, 2014 | 09:38 AM
LetsGetThisDone's Avatar
You can use any automotive solvent from your local parts store. Degreaser or carb cleaner will cut through the oil better. Finish it off with brake cleaner and you'll be all set..
Old Jan 2, 2015 | 05:59 PM
mrowka's Avatar
From: Driving ten under in the passing lane, right turn signal on at all times.
Originally Posted by todd6027
dishwasher
ya'll have wives?
Old Jan 3, 2015 | 11:35 AM
Originally Posted by mrowka
ya'll have wives?
I bought an old one off of CL for $100, and had it in the garage until it quit working. Worked wonders for cleaning big engine, transmission, and drive-train parts. And we have parts washer tank for smaller stuff more intricate stuff. The dishwasher went out and we have never replaced. Probably should, it was an awesome "tool".
Old Jan 3, 2015 | 06:43 PM
robbyredneck's Avatar
2 cans of brake cleaner an hour of my life and a half gallon of diesel. and thats after a spun bearing. it's tough getting them clean. i have a wife but i am the dishwasher.
Quick Reply: Oil Pan Cleanup
