Solid side diff supports without mustache bar
So I made some adjustments to my side diff supports and now I am running solid 6061 aluminum mounts, I currently have my own version of the AMS MBE, but I was wondering what the hell it even does with solid side diff supports.
The only thing I can think of is that it helps with the diff flipping backwards, but if you have the solid diff supports what does it do?
Same thing with the rear trans mount. I run a solid front cross member and avid side mounts. I don't see a need for a rear trans mount.
You would be forcing the bolts that secure the side mounts to the chassis to take a bending load. Fasteners don't like bending loads.
Consider the reaction torque, the diff sees roughly 3x more torque around the axle than around the pinion. That bracket carries that reaction load to the torque into the rear subframe.
antilag_200
46
Jun 4, 2018 07:25 PM
detroit pistins
Aug 18, 2016 02:09 PM
kpt6
Sep 22, 2015 08:40 PM
ryukinevo
92
Sep 6, 2014 11:39 AM
TwStDeVo
Jan 13, 2013 10:04 AM
