ECU triggered relay for 2nd pump
So I'm trying to troubleshoot why my second pump is running full time once ignition power is on. Main reason for this post is to check the relay wiring, because if I can't rule that out, then cussing the AEM and changing settings is fruitless.
so here's a picture of my relay:
the non-connected pin is my fused power source from battery, disconnected so I could get a picture.
Pins:
30 - fused power from battery
85 - ground to chassis
86 - signal from AEM (pin55, LS5 output)
87 - output to pump positive
If my relay is wrong, i'm guessing it has to do with chassis ground. My understanding, however, is that the relay will be circuit "open" until energized by the ECU on 86.
Am I retarded and wired the relay wrong?
Pins:
LVSBB6
Sep 23, 2013 02:29 PM
Carloverx
14
Dec 22, 2011 01:00 PM
GGevoXftmfw
May 10, 2010 10:43 AM
