EVO 8 -- Max hp and psi ?
Hello,
Just wondering is 26psi safe on stock rods and pistons on a Evo 8 mr, with the following mods?
- 3"TBE
-E85
-Arp head studs
-Cometic head gasket 1.25mm
-CAI
if so what is the threshold of the 4g63 with stock rods and Pistons both in hp and psi, looking to buy cams to reduce torque down low and add up top, any help would be appreciated !
- 3"TBE
-E85
-Arp head studs
-CAI
How much hp can they take if like you said the tune is spot on, I no the torque is a big reason they can fail that's why I'm trying to push everything up top as close as I can to reduce boost early on plus with the cams it will reduce abit down low, just wondering what should I watch out for more, the hp or the torque when it comes to making power on the stock rods and Pistons.
Okay that's what I was looking for I just gotta be careful of the torque, hopefully make a close to 400hp with under 400tq might be bit of a challenge though
DeavenKrietz
Sep 18, 2015 09:55 AM
DynoFlash
15
Aug 23, 2007 04:57 PM
blackfly
Mar 27, 2004 07:57 PM
