advice on bolt on upgrades
So just took the motor out its a the machine shop getting hone, bored, decked head, et. they are rebuilding the motor to stock block basically pistons rods and crank all stock.
its goin to be a daily driver these are the mods that i do have already
full injen intake
3in turbo back exhaust.
act hdss clutch ( needs to be replaced) still thinking what I am goin to replace it with. I been thinkin about competition s2 or s3.
upgrades thinking about
evo 9 turbo with 02 housing
upgrade on cams goin back between gsc s2 or brian crower 272 or 276 or a stage 1 cam also.....
and of course tuning
any input? all on pump gas 91
full injen intake
I was running gsc s3 cams on my stock 9 turbo. Was making 310whp at stock boost. Bumped it up to 28psi and was making 350/350 on 91 **** gas. So S2 cams will be no issue. The competition stage 2 clutch is a great option. But I suggest you upgrade your rods since you're doing a rebuild anyways. You can get I beam rods for under 500
mods depend on what your goals are. we all have different ones, so you will get 100 different answers.
the stock 9 turbo is a GREAT upgrade and plenty if you have access to e85. at your power level, another HDSS should last forever (unless abused) and be easy to drive. cams really wake these cars off. if you are going for peak power, S2 is a really nice cam.
all just an opinion, of course.
Well I drive a porsche 993 daily for work sometimes putting up to 1200 miles weekly, bought the evo 8 to be my daily it would be less for me in maintenance on my 993 then the evo. I autocross so the evo would have dual purpose.
I need the evo to be a solid car. I know it is and fun to drive. I am trying to get up to or around 400hp but as a daily on pump gas (its a wish) . I am rebuilding the motor with stock parts. I can probably go ahead and upgrade the rods. But I am thinking about is send my turbo to turbo lab america and do a rebuild upgrade to a 20g billet with Evo 9 tdo6sl2 turbine housing and turbine upgrade with 02 housing. using gsc s2 cams with springs, I already have intake and turbo back exhaust. Tune of course.
Is this a wet dream of getting 400hp on pump cali 91 gas?
