Stm balance shaft inspection hole breather fitting
Old Apr 6, 2015 | 09:21 AM
LetsGetThisDone's Avatar
I used a 150* fitting, and routed the hose out in between the compressor housing and the block. However, this fitting pushes a lot of oil. It filled the radium catch can it was on fairly quickly. I wouldn't run it unless you want to drain the catch can at <1000 miles intervals, or you have a big can. When I took the hose off the fitting to remove it, oil came out of the hose. Also the catch can was full of oil, not just standard condensed crank case vapor goop. So I really don't recommend this fitting for non-racecar use.
I've since went to just running two -10 lines out of the valve cover. Works like a charm..
Old Apr 6, 2015 | 10:24 AM
snafufx's Avatar
Thanks, you're the second person to mention that. It was a toss between that or dipstick vent. I might just block a port off the catch can and just run it from valve cover. I'm barely losing oil now so thought that would help.
Old Apr 7, 2015 | 11:22 AM
kaj's Avatar
kaj
I don't daily the car, so this may still be an.option for me. I popped a turbo at a track 3.5hrs away from home. I'd like to do anything I can to reduce the chance of that happening again.
Old Feb 3, 2018 | 03:11 AM
leecavturbo's Avatar
Anyone got a pic of this ? And is it on the block? Because I thought the better place is at removed shaft front case hole as it's much bigger -14 maybe bigger ?
Old Feb 27, 2018 | 01:49 PM
Perhaps there is a location further a long the shaft hollow to clear turbo better but will need a flat surface ground on for sealing and obviously drilled and tapped ?
Old Dec 22, 2021 | 10:23 PM
VeebeeIX's Avatar
Digging up an old post instead of starting a new one.
Is this needed when going over 700whp and wondering if it will fit with a morrison fab TS manifold with EFR8474 ?
And then on that note, for the valve cover is the -6AN fittings wide enough to allow enough flow or would it be better to drill for -10 fittings ?
Old Dec 23, 2021 | 06:07 AM
Abacus's Avatar
I'd stick with two -10 fittings on the Valve cover. I'm using that setup at 1000-1100hp and it moves a small amount of oil into the catch can after some runs. Thats on a well used 2.2 with 25K on it.
The following 2 users liked this post by Abacus:
ronaldo9 (Dec 23, 2021), VeebeeIX (Dec 23, 2021)
Old Dec 23, 2021 | 08:04 AM
VeebeeIX's Avatar
Thanks, will do that.
My engine is fresh, was just put together and about 200km on it. Still running it in on a gt3582r.
Just ordered a Morrison TS kit and efr will be going in sometime July next year, so I'm sure I will need the extra crankcase vents then when turning up the power.
Old Dec 23, 2021 | 10:34 AM
ViciousLSD's Avatar
Do you have Kigly/crank scraper? Do those help in reducing oil in the PCV system?
Old Dec 23, 2021 | 03:13 PM
Abacus's Avatar
Not sure, The engine was built back in 2007 so I'm going to lean towards no.
It gets turned 9200-9500 often.
Blue91lx
37
Apr 9, 2015 06:07 PM
ch53avitech
Jan 19, 2015 07:16 PM
mrfred
Oct 22, 2013 12:13 AM
Blue91lx
10
Jun 27, 2012 12:33 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
Quick Reply: Stm balance shaft inspection hole breather fitting
