Stm balance shaft inspection hole breather fitting
Old Apr 4, 2015 | 09:16 AM
snafufx's Avatar
This "easy" mod has been a complete nightmare. I took out radiator, unbolted manifold to get enough room to take the oem balance shaft bolt out. Finally got it out after 2 hours or so. Prep my hose, my Megan o2 housing is blocking the path. I switch a straight fitting with a 90 degree fitting, still no go. I even tried just connecting the hose straight to the bolt and still couldn't get it in. I hear a lot of people on here did this mod, what exactly did you do to get this to work? FP Black turbo, so it isn't a front face or anything like that. Just stock location everything pretty much. I do have the balance shaft delete kit so should be "simple" as screw it in, connect an fitting and run it to catch can.
Old Apr 4, 2015 | 09:22 AM
michaelrc51's Avatar
It is really close to a stock framed turbo. I ended up using a low profile fitting but it was still a huge PIA just to get the fitting on the adapter coming off of the block.
I took the turbo out and then out and then put everything on but it had to be orientated just perfectly not to touch anything.
Old Apr 4, 2015 | 09:31 AM
snafufx's Avatar
Thanks, was it something like this then?
http://www.summitracing.com/parts/fr...6-bl/overview/
Wish I would have known this before starting this project.
Old Apr 4, 2015 | 10:14 AM
Think I ended up using a 45 due to the angle but honestly I don't remember.
Old Apr 4, 2015 | 11:08 AM
snafufx's Avatar
Thanks, anyone else? I don't want to have to purchase a 90 and 45 at 20.00 a pop.
Old Apr 5, 2015 | 08:55 AM
okevolutionVIII's Avatar
When I was still on a bottom mount turbo kit, I was going to use a -6an banjo fitting with a steel line as I was having the same clearance issue.
Old Apr 5, 2015 | 09:12 AM
kaj's Avatar
kaj
first i've heard of this. what's the purpose? sorry if off topic, i'm just curious.
Old Apr 5, 2015 | 09:15 AM
Extra crank case ventilation.
A banjo would limit the flow but is definitely a lower profile.
Old Apr 5, 2015 | 09:18 AM
kaj's Avatar
kaj
oooh. interesting, except it seems to not work with stock-framed turbos. i would like to keep pressure out of the crank case, though. assuming this works better than venting the valve cover?
Old Apr 5, 2015 | 09:25 AM
It does work but it is a real PIA to get the fitting on it once it is in the block and turbo in place. I guess each situation is different but it takes a bit of messing with and trying different fittings.
With my new setup I am not using it. I think it may push a decent amount of oil out of it. But it definitely adds block ventilation.
Old Apr 5, 2015 | 10:09 AM
kaj's Avatar
kaj
awesome, thank you.
Old Apr 5, 2015 | 12:39 PM
snafufx's Avatar
I'm getting a little closer. From reading it's either 120° or 150° fitting. It would have been so easy if they added this to their kit.
Old Apr 5, 2015 | 02:48 PM
Macaroni's Avatar
I'm using it with a stock location Borg Warner and it's also very close but I didn't have any issues putting it on.
Old Apr 5, 2015 | 04:08 PM
snafufx's Avatar
Do you remember what angle fitting you used? That's my issue
Old Apr 5, 2015 | 05:17 PM
Macaroni's Avatar
I'm using the 90* that came with it and have it pointing down
Quick Reply: Stm balance shaft inspection hole breather fitting
