Engine problems
Engine problems
HI
I dont really know what to do with my engine anymore.. I have been asking toons of people and i get the same answer everywhere.. Crankwalk, Well that isnt the case, I build and have been building engines for over 15years but never had this problem before. As soon as i touch the clutch the engine drops rpm, and if i floor the clutch pedal ( it is right adjusted) i drop almost 8-900rpm. Thrust play is 0,0059" the Only new parts that i haven't had before is drysump from magnus and a manley crank. I have narrowed all bearings and Also filed on the thrustbearing so the would be more oil to the thrusts.. All bearings is checked and new acl tri metal.
i have took apart the engine 3 times now and i cannot sort the problem out because i cannot find the problem
Anyone else experienced this problem?
