Boost lag?
Boost lag?
well about 2 days ago i noticed that when i hit it full throttle in 3rd at about 5,000 rpms my rpm level goes down to 4,500 and then climbs back up normally. do any of you know out there what this could be or if it has happend to you? if it was my clutch i think it would happen on all gears but it ONLY happens in 3rd. and it just goes to 5 and back to 4,500. it wierd. maybe the synchros? Any help would be greatly appriciated. thanks
does the car fall on its face then come back again? if so i would think fuel cut. has it just happaned after you put some new gas in the car? might be bad gas?
Alex, sounds like a boost leak, not lag. Lag is when you start in 1st gear and wait till the turbo spools. That area of no power before boost is the lag. Check all your hose clamps and around the BOV. Maybe the BOV is not holding.
A slipping clutch would mean the RPMs are climbing and you are not accelerating to keep up with the RPMs. You are having the opposite problem with the revs falling. Keep an eye on your boost gauge to see if you losing boost or not boosting as high. Don't know what else it could be
Have someone help you get to all your hose clamps and tighten them all doen. Mine were loose. I couldn't believe how many turns I had to make with the rachet. If your problem continues, since you are mostly stock, bring it in to service.
BadKarmaCreepin
Dec 15, 2011 03:59 PM
jorge mr
10
Nov 30, 2008 01:38 PM
veritech137
26
Feb 4, 2004 06:29 AM
