Turbo CHRA v-band leak
Old Jun 6, 2015 | 07:48 PM
Locdizzel's Avatar
i think I'm sealing these turbos wrong some how, but the 2 turbos i've installed are both leaking from the v-band. i've tried new v-bands and clamping extra tight, rubber mallet to hammer it together and some other things and can't get it to seal correctly. can someone let me know what I'm doing wrong, evo 9 turbo FYI
Old Jun 7, 2015 | 04:35 AM
Boost Demon's Avatar
Veteran: Air Force
I have to ask only because I didn't see it mentioned, but is the small locator pin from the hotside going into the CHRA completely? Any rust or debris on the mating surfaces? Are any of the compressor blades bent?
Old Jun 7, 2015 | 07:23 PM
Locdizzel's Avatar
no rust and i cleaned the carbon off with a small wire brush, nothing aggressive tho. the pin is there on the new turbo and the leak is very minimal. my other turbo it broke off but i could still line it up good. no bent fins or anything on either turbo
Old Jun 7, 2015 | 08:17 PM
LetsGetThisDone's Avatar
Exhaust leak, or oil leak?
Old Jun 7, 2015 | 10:04 PM
Locdizzel's Avatar
exhaust leak
Old Jun 8, 2015 | 09:14 AM
That's weird, the exhaust shouldn't want to got that way. Is the heat shield that is supposed to be behind the turbine wheel in place?
Old Jun 8, 2015 | 02:09 PM
Locdizzel's Avatar
yea, I took it apart again last night and cleaned it up with break cleaner again and was able to get it to seal good today
mrm95
37
Jan 13, 2019 02:41 AM
sujinX
Oct 12, 2013 12:17 PM
ExViTermini
Apr 16, 2009 08:26 PM
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
Quick Reply: Turbo CHRA v-band leak
