Heat reflective tape
I picked up some aerolite plus heat reflective tape. I wanted to see under hood pics of where others use it to for best effects. I'm looking to keep my temps down as much as possible.
I will be wrapping my MAP DP and ported stock exhaust manifold, and throwing some coats of VHT flameproof on those also. My turbo hotside is already ported and coated.
Here are the test numbers on the heat reflective tape.
Supposed to be 96% reflective
i used the gold stuff on my oil pan (before i wrapped my DP, but now i have both) and oil return line (since i was down there LOL). i run the stock exh mani, so haven't put any on the valve cover (i could see it being useful for the taller, tubular manifolds). i've seen some people use it on IC piping, but i can't really see that helping seeing how mine aren't next to anything that gets that hot.
maybe the inside of heat shields? i think those would get too hot, though. i dunno
if i had enough, i'd do the tunnel above the exhaust.
i've seen a lot of people use it in other places, but i think it was just for looks.
http://www.coastfab.com
(714)842-2603 They will send a sample of both and a catalog if you call them, and they are in Socal.
Post it if you find it
Fortune-Auto
72
Oct 8, 2014 11:20 AM
Fortune-Auto
EvoX 'For Sale' External Engine / Power
65
Oct 26, 2010 09:34 AM
Indy Evo
62
May 28, 2010 08:13 PM
