How Difficult to Change Radiator?
Old Jun 15, 2004, 11:49 AM
TonyG's Avatar
You may want to consider fixing the old one. After taking the old one out, I got a better look at the hole and realized that it was really tiny (less than 1 mm). The leak looked really bad when it happened because the fan was spraying the collant all over teh place.
I'm sure a radiator shop could have easily fixed it. But I already had the new one when I realized this, so I just threw it in.
Old Aug 26, 2004, 01:26 AM
Registered User
MyCre8n=Evlshn's Avatar
Hey! Why is the KOYO so much cheaper than the PWR?? They seem like they're about the same to me at first glance. Anyone know? (I know...off topic...but I don't want to start a whole new thread comparing the Koyo and PWR radiators...that seems like it would just clutter the boards)
Old Aug 26, 2004, 01:35 AM
sophis's Avatar
I doubt the price quoted for the Koyo is the aluminum racing version.
This was how I removed my radiator:
1. Remove air intake
2. Remove battery and upper i/c pipe
3. Drain the radiator fluid
4. Remove the upper radiator hose completely
5. Remove the lines going to the fan. I kept the fan on when I removed the stock radiator
6. Disconnect the bottom radiator hose
7. Unbolt misc bolts on top of radiator/brackets and carefully lift up radiator. Be cautious of hitting the exhaust manifold heat shield.
Old Aug 26, 2004, 08:14 AM
Zeus's Avatar
Koyo has an OE replacement, and an "upgrade" unit... the latter being in the $400 range.
Evoryder
Apr 29, 2019 10:09 AM
Spythere
Jul 5, 2016 03:09 AM
WANTSUM
Jan 24, 2014 04:46 PM
David Buschur
Oct 3, 2011 03:49 AM
triple L
Mar 22, 2011 09:47 AM
Quick Reply: How Difficult to Change Radiator?
