Gsc beehive 5039 vs tomei springs.
Has anyone compared these two springs, i see the tomei springs are rated up to a 12mm lift, but no information on if its used with stock seat and retainer. If so how does the spring rate compare to the gsc beehive springs on stock retainer and seat.
Ill be running a tomei 280 procam but i have the beehives already installed, what to know whats the limit on this setup.
They are only good for 11.2mm of valve lift. Your cams have 11.5mm of lift. They will not work. You need to upgrade to the GSC 5040 or 5041, or install cams that have less lift..
06RedRalli
Nov 27, 2017 04:52 PM
FS[SouthEast]: FS: EVO 8 GSC s2(274/274)cams + GSC Beehive springs(5039)
_des_
Feb 3, 2016 07:56 AM
EnjoyDriving
Jun 27, 2011 08:55 AM
EnjoyDriving
11
Jun 26, 2011 08:57 AM
EnjoyDriving
Jun 15, 2011 07:47 AM
