Fuel pump rewired questions
Old Jul 27, 2015 | 09:47 PM
DSMolition's Avatar
I rewired my dw320 lph pump to get the most voltage using a relay. Now I'm having trouble with my aeromotive regular getting it below 50psi base pressure.
Is my regular spring bad?
Old Jul 27, 2015 | 10:53 PM
mrm95's Avatar
I did this a month or so back. you have to take out the fuel pump assembly and drill out the siphon tube using a 9/64" drill bit.
Disconnect the siphon tube and drill it out. I circled the part in red that needs to be drilled in the picture attached
Old Jul 28, 2015 | 05:17 AM
DSMolition's Avatar
Thank you so much I will do this!!
Old Jul 28, 2015 | 12:25 PM
mrm95's Avatar
No problem. i had the same exact issue as you did after rewiring my Walbro 450
boyvang
Jul 13, 2018 06:20 AM
aggieEVO
Apr 29, 2013 03:45 PM
Carloverx
14
Dec 22, 2011 02:00 PM
redralliart04
04-06 Lancer Ralliart How To Requests / Questions / Tips
95
Sep 20, 2008 01:04 AM
g0damy0uugly
Mar 8, 2006 12:28 AM
