2.4 LR - smooth as stock motor?
So I'm waiting around and thought I'd start this conversation
In my past DSM I had a Magnus 2.3 w/o balance shafts. It was allot of fun!
The problem was Magnus never mentioned the second hand harmonic vibrations or piston slap that would occur. The vibrations were bad enough to loosen engine bay bolts monthly....yet you could barely feel anything from inside the car. Even an aftermarket damper would not resolve the vibration.
Fast forward many more years than I care to admit and I'm enjoying my Evo IX with a green turbo. I recently upgraded to the 4.11 gear set and I'm thinking of "one day" going for a 2.4LR as my daily driver.
The question is, can a 2.4LR be built to be as smooth and quiet as a stock 2.0 If the goal is to stay at 500whp or below?
off set wrist pin means the pin is not centered in the piston. factory pistons are offset . offset pistons run quiet. centered make slightly more power and can be used in both early 4g63 and the evo 4g63. offset piston would need to have two different pistons. the offset can only be run in one direction.
smoothevox
13
Jan 28, 2009 07:17 PM
