Evo 9 Cam Gear Rattling? Help!! Video Inside
So lately I've been having this on cold starts but now it happens even when the engine is at operating temp. It sounds like something is rolling around in the MIVEC cam gear. Is that even possible or does anybody know what this could be?
Thanks
Thanks
Well I'm not gonna run it so I won't be messing anything up and I don't want to start tearing things apart ***** nilly unless I have some kinda clue as to what it could be.
Surely someone else on here has had the same issue?
EDIT: Does anybody know if something could be loose inside the MIVEC cam gear? It sounds like it's coming from there but sound does travel so I'm not 100% sure.
you are talking about something in your Mivec gear not right. If that fails you will be rebuilding your head and spending tons of money.
Just pull your timing belt and take the gear off.
IMO you are being pretty stupid by not wanting to tear into it. There IS something not right in there and you aren't going to fix it without getting in there anyway.
Invincible
Sep 20, 2012 01:05 PM
Kevin Knight
Sep 5, 2011 02:58 PM
nbpal4000
Jun 25, 2004 12:08 PM
