New FP green dosent sound right
2005 Evo 8
181k
I just installed a brand new FP green from fp directly. Unfortunately I had to run with an open downpipe for about half that time because my flange on my exhaust had a different flange from my downpipe. Now I have the whole exhaust hooked up and it sounds not good.
The sound sounds like a supercharger and is extremely quiet compared to my stock turbo I had on it. I checked for shaft play and there is none. No contact on compressor housing. No smoking either. It also boosts fine.
I haven't done a boost leak test yet but that will be done today. The quiet part is what scares me. Why is it much quieter than my stock turbo?
181k
Does it have the anti surge compressor cover, or the stock appearing cover? Is it journal bearing or ball bearing? We will probably need a video of it. Your post is confusing. You say it sounds like a super charger, but then you say its quiet..
Yes it has an anti surge cover and is also ball bearing. For the quiet part I meant it is quieter than my stock turbo I just had on it. Like the stock 16g spooled louder than the FP green I have on now. The FP green spools but has like a supercharger whine but it's quiet. I expected it to be louder than the stock turbo.
I'm not understanding your noise. The anti surge cover makes quite a whistle/whine/whooshing noise while the turbo is climbing into boost, and the turbo makes a bit of a whistle once on boost. As long as it doesn't sound like a kazoo, you're probably fine...
Alright maybe it is the antisurge housing then. I've never had any experience with one so maybe I'm not used to hearing the noise.
foxracing515151
Oct 25, 2014 08:07 AM
edogg23
Sep 23, 2009 09:23 PM
