Shift Linkage question
I was shifting fine when I was taking my friend home from the airport and when I was on my way back, suddenly 4th wasn't working. I shifted back to 3rd just fine until I hit a red light and I lost all gear. I checked my shifter cable bushings and they were fine. I got it into first gear to the next light then I lost all gears again. I kept checking the bushings and all shifts were finally gone.
I messed with the bracket that the shifter cables are supported on and got it home in 1st (I was like 30 seconds from home) and I go back in to my hood and see what I think is the roll pin coming out of the side of the linkage. I suspect this pin is the culprit cause now I can't get any gears to lock by hand via the selector.
So my question is, how do I get the shift linkage out? I got the 5 bolts on top out, but it won't budge still. I can't find that last bolt to get it free, where exactly is it? I tried looking for pics but couldn't find any. Is there any way to push that pin back in without taking the linkage out? Thanks in advance!
EDIT
Well, I think I figured it out..
EDIT
xiMR
Jul 22, 2016 09:23 AM
BuiltS13
Jan 24, 2011 02:03 PM
