on idle my vaccum fluctuates a bit
I was wondering if this is normal with turbo cars. Bascially the vaccum fluctuates up and down on idle, it is like it is vibrating. The range is tiny but it fluctuates on a steady pace. All lines are tight and this is on my DEfi BF series boost gauge. Anyone have this or info on this?
TIA
TIA
I think its normal, Mine does that sometime, especially when the motor is cold, it fluctuates in .5 psi range between 18-17 in vac. My car is completely stock. spike to 20psi tapper to 17 and hold all the way to redline. I wouldn't worry about it.
1 Post
slight fluctuation is normal... at idle on a cold motor it should be slightly different than that of a warm motor... A warm motor should see at most 1 PSI fluctuation... Don't worry if their is a vacume leek you will either see the vacume loss or hear the leek. Normal leeks can see an excess of 5-8 psi of loss if not more... depends on the size of the leek
why does it vaccum at idle?? I've been wondering this for awhile. I know that this is a stupid noob question, and I have done a search and didn't really find the answer, so any help would be appreciated
tsherriff
Nov 29, 2007 11:20 AM
