2.3L Piston advice
2.3L Piston advice
I'm shopping for a set of 2.3 stroker pistons (86mm bore) for a 700HP Evo 8 (34psi boost). In the past, I almost exclusively used JE & CP pistons, the 2.3L CP's are around $700 but I just noticed that Manley offers stroker pistons at $500ish which is significantly lower in cost!
Would you recommend them for such high powered Evo?
Get Wiseco HD's in 9:1 compression from ExtremePSI, they're a bit less than $550.
http://www.extremepsi.com/store/prod...at=1586&page=1
2.3L Piston advice
Yes, it's the same piston. It goes up a tad because they don't change the dome size enough as the vote increases. The slight higher compression from the bigger bore will be fine. You just don't want the 10.5:1 comp ratio Pistons.
crcain
Apr 29, 2009 12:38 PM
bradc
Feb 28, 2009 02:19 PM
kkarim
Feb 11, 2008 05:40 PM
gofaster87
Jan 8, 2007 03:30 PM
