Evo ix hard to shift keeps blowing ignition fuse
Just an update it ended up being that dam ring on the pressure plate for the retainer being bent so ACT Monolock is going in and should be good to go. Such a crapy design. I would convert to push style but too expensive for my blood right now and I have heard that the monolock does the trick.
So that metal ring was cockeyed but still on enough so I still had a pedal but it was only pulled half the pressure plate teeth out when the clutch was pressed sonic was staying engaged.
TO ANYONE AND EVERYONE DOING A CLUTCH. BUY THE ACT MONOLOCK. DOESN'T MATTER WHAT BRAND CLUTCH YOU HAVE IF IT'S STILL A PULL STYLE DO NOTTTTTTTT PUT IT IN WITH THE STOCK STYLE TWO PIECE RING. YOU WILL BE TAKING YOUR TRANS OUT TWICE BELIEVE ME. ACT MONOLOCK PERIOD!!!
bml1024
Feb 6, 2017 11:34 AM
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
Darkn3s
Nov 20, 2013 07:49 AM
