GSC springs not enough lift for Kelford 272?
Just bought a set of Kelford 272 cams to replace the BC272s that were in the car when I bought it. Previous owner installed them with stock springs/retainers so Im getting upgraded ones for these cams. While looking for springs I figured the best bet would be the GSC valve spring kit. I looked up the specs and the maximum valve lift for GSCs is 11.2 mm. The maximum lift for the cams is 11.0 mm. Should I be worried about this? I dont know if 0.2mm is enough clearance before bottoming out or if I should just buy the Kelford spring set and use those. I believe the max lift on those ones was 13mm.
http://www.ebay.com/itm/GSC-03-06-MI...tR0So9&vxp=mtr
It must have something to do with upgrading the retainer set too then. I was just going to do the springs because I dont really plan on revving out to the moon or running over 26 psi. This set says 11.2 max lift because of stock retainers..
If they bottom out, the valves are floating.
They'll be fine.
They'll be fine.
evo8vz
Oct 12, 2016 01:42 PM
Sideck
10
Jul 13, 2010 08:50 PM
tristat3
Mar 9, 2010 05:48 PM
TalonRcR
34
Aug 8, 2005 01:03 PM
