The journals on my crankshaft are .5mm undersized
is it still safe to use?
my machinist told me I can use standard bearing just to check my clearances with plasticgate
No, .5mm under is an increase in clearance of .020". Your clearance should be around .0015-.0025 on stock parts. So with the crank undersized you would likely by around .0215-.0225" bearing clearance. Which is way far and beyond too much. You most definitely need oversized bearings.
Unless you machinist isn't quite as dumb as your post implies, and he said .5 thou, as in .0005". Which should be OK to use as long as you check the clearances.
But if he is truly saying a .5 MILIMETER cut crank is good to use with standard bearings, find a new machinist.
4G64 cranks are cheap so not worth risking my build
LGshow19
Jun 9, 2012 11:19 PM
GetPowerHouse
Sep 26, 2011 12:27 PM
shunderwunder
11
Apr 16, 2009 07:35 AM
MitsuJoe
Dec 1, 2008 06:30 AM
