Evo 9 mr blow off valve install?
Hello guys. I do not know whether this is a silly question or not. Must the plunger side of bov be toward air intake-turbo hose? I posted a picture showing how i installed it. Can wrong install of bov cause blown up engine? Are mr bovs adjustable or i must install it the way i took it out of a box?
The last picture is correct. The part closest to the nipple on top goes to the intake BEFORE the turbo. The bottom part opposite of the top/nipple side goes on the IC piping.
They are not adjustable unless you crush it. It will then hold a bit more boost
Then i installed it wrong? Because there are a lot of pictures on the internet showing that the plunger side must be toward intake turbo hose. Thats why i do not which one is correct. I drove in both ways but i could not be sure which one is the right one
You won't blow your engine this way, but you will ruin your turbo over time due to turbo surge. I wouldn't worry about any damage done if you're running around stock boost levels. Just fix the diverter valves orientation and you're good to go.
-pal215
That's correct. The spring loaded plunger side should be facing boost pressure and therefore be connected to your upper intercooler pipe. The hole that you see a metal stem in should be plumed into the intake manifold.
-pal215
-pal215
-pal215
-pal215
The intake pipe itself that runs to the opening of the turbo and is exposed to the atmosphere through the filter element will only experience vacuum.
The way you have it installed now is not correct. You will want to make it like the 3rd picture down, not like how you have it in your first picture. Evo Motorsports picture is correct.
-pal215
That's ok, remember that the intake manifold and upper intercooler pipe are separated from the intake filter by the turbo charger and intercooler assembly. They will always experience vacuum or positive pressure.
-pal215
-pal215
importdps
Import DPS - Philadelphia, PA
Dec 13, 2011 08:54 AM
MasterNater
15
Jun 21, 2009 08:13 PM
TunerHead24
Apr 8, 2007 09:46 AM
chewymang
13
Aug 27, 2005 03:09 PM
