Choosing the correct piston for 2.4L 4g64 block
#47
The trouble with buying special pistons is that the dish volumes are usually wrong.
You need to know the combustion chamber volume, the piston height at TDC, the gasket thickness,
They're all variables and aftermarket rods are often a slightly different length from stock, as are all the other parts.
If you don't measure, you won't know.
Whatever you think the CR is, it won't be.
I've been through the whole process with other engines in the Mitsubishi family and everything is wrong.
TrendSetter
Aug 29, 2017 08:34 PM
djikonatx
60
Sep 13, 2013 11:08 AM
mrboost05
Mar 6, 2013 09:58 AM
bostonhatcher
26
Oct 10, 2012 08:33 AM
