Converting ACD T-case to Non-ACD
Ok..so a little background.
I have a complete Non ACD case with a burned ring and pinion, I also have a perfect ACD case off a 2005 MR with 21,000 miles. It looks brand new on the inside. The Non ACD case came off of my EVO VIII and burned its *** off from a seal failure.
I would prefer not to disassemble the pinion gear and transfer it to the NON ACD case. Too much BS (preload, pinion depth and side bearing clearances to mess with)Plus the NON ACD case bearings look like complete ****. So I would like to see if I can retain the ACD case if possible. Other post said this is possible if I move the non acd viscous coupling over and swap diff housings and the cover. But the bolt pattern is completely different and there is no viscous coupling in the non acd T-case. So WTF?
What is the procedure if someone has done this before?
just did one last week.
use the acd case. remove clutch pack. remove ring gear from diff housing. remove lsd diff from housing as well.
use non acd diff housing, installed with acd ring gear and lsd diff. use non acd cover. easy peasy dude. dot know who' making it difficult. bolt patterns are the same.
NOMIEZVR4
Oct 18, 2013 01:28 PM
DubsE46
10
Mar 20, 2012 12:34 AM
konstantinosIX
Jan 8, 2009 11:17 PM
