boost
boost
How much max boost can u run on a 2.3 4g63 9.1 with gsc r2 stroker cams gsc valve train mild port stock TB with 1800cc fic 450lph walbro intake on pump 93 and e85 ets 3.5 fmic
134.7psi with a 117mm turbo
Be very careful, if you run 134.8psi, or a 117.5mm turbo, you'll experience a nuclear detonation.
So you're asking when that turbo stops becoming efficient then? if you can find a compressor map, then it'll tell you the efficiency range.
But judging by your original question, you have a lot to learn. Tons of good info around the forums and a lot of questions have been answered over the years. Google is your friend.
[QUOTE=Teal2nnr;11578969]So you're asking when that turbo stops becoming efficient then? if you can find a compressor map, then it'll tell you the efficiency range.
d over the years.
O YEAH I WILL TRY TO DO THAT THANKS FOR THE INFO
d over the years.
bwanner
Aug 31, 2012 05:38 PM
wfochris
Dec 22, 2009 10:33 AM
wingnut
Jan 20, 2005 11:11 AM
