2.4lr Boost creep issue need advice
Setup is a 2.4lr, ets t3 manifold w/mvr wg and 6266 turbo. Tom from Tscomp has been helping me with the tune and we have the wgdc at 0 (was targetting 19-21psi) so it's running off wg spring. 18psi combo hit 36psi and 11 psi hits 28psi. Both setups seem to hold boost fine until after 6-6500rpms and it ramps right up. I am thinking of trying an 8psi combo but I feel it shouldn't have to be that light of a spring to not creep. I guess I'm looking for some advice at this point.
Do I run a second WG?
Is the ETS manifold the issue?
Is this common with 2.4s with ported heads?
Thanks
Thanks
Why are you trying to run such little boost on a big turbo set up like that?
Thanks
Thanks
1. no
2. no
3. no
Run the lowest pressure spring that creeps the least amount and ill take care of the rest from there.
Once I introduce a load to the gate it will stop creeping.
Id like to see around no more then 20psi creeping uptop as a baseline to start with.
I think the spring chart you're using is not accurate either, so just work with real world results not paper in this case.
Also 2.4's work turbos much harder then 2.0's so what might look like low boost is really not for a larger displacement engine.
30psi at high rpm in a 2.4 is like 35-36psi in a 2.0 as far as airflow goes.
Is it a single or dual gate manifold?
If the manifold only has a single wastegate, this is why the new ETS manifolds have dual wastegates...
Id recommend adding a boost cut first before we go any further to avoid boosting past a specific threshold. Just email me the most recent logs so i can check the load and adjust the cut based on load averages from your car.
wtfisak24
Nov 10, 2011 02:42 PM
EVIL_EVO_VIII
127
Feb 27, 2007 05:34 PM
