Would you use this crank?
Just got a 100mm crank out of a galant for my 2.3 build, 2 of the lobes have noticable pittings, my fingernail drags on them (I can feel the pits), but it does not look too deep, do you guys think a micropolish would clean this up?
Needs to be cut .010" undersized if you wanna use it and end up with proper oil clearance.
ahh yes, kinda makes it hard because there are no good machine shops (atleast from what i know) here in my area, yes they are nitride treated, and if you take over .020" off I believe it cuts the treated layer right off. I think I need a new damn crank :/
Originally Posted by kaj
I assume it means because you want to keep the radii on each side of the journals. I forget what they are called.
Also, are our crank journals nitride treated?
All of that gets cut when you under size the crank. It'll be fine if have someone that know W what they're doing cut it..
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
