New help. Broken ring lands...need shop advice
Need help. Broken ring lands...need shop advice
I'm looking for a good shop to help with my EVO IX MR. I've had issues with this car for the past couple of years that no one can seem to fix.
Over the past two years, the car has run for a total of a few months. This was AFTER an engine rebuild, and turbo upgrade. The car is being repaired now free of charge because it never ran right from the day I got it back this last time, but the cause of the failures was never accurately determined, so there's no guarantee that it won't break again even though it will be on a freshly built motor.
It's been the same thing every single time. Broken ring land, on cylinder one. When the original motor blew, that was the problem. Then the built motor blew TWICE on the exact same issue. I need a shop to look this car over, find the issue, and fix it along with any other issues it might have so I can get back to enjoying, and racing this car.
Below are the parts used for the motor build. It is their stage 1 package that is supposed to be good up to 600whp. The mods I have on the engine are also listed. If my stock motor had not blown, I would have been happy just to keep the bolt ons on stock motor, and stock turbo.
ACL Race Main Bearings (evo 8/9 (5M1219H)
ACL Race Main Bearings (evo 8/9) standard size
ACL Race Rod Bearings (Evo 8/9) (4B1185H)
ACL Race Rod Bearings - 7 bolt standard size (Evo 8/9)
OEM Thrust Washers (Evo 8/9) (MD351820)
OEM Thrust Washers (Evo 8/9/X)
ARP Main Bolts (Evo 8/9) (207-5401)
Manley H-Beam Rods Evo 8/9 (14022-4)
Manley H beam rods evo 8/9 2.0L
JE 4G63 2.0L +.020 (278906)
JE piston, +.020, 9:1CR 2.0L evo 8/9
OEM Balance Shaft Elimination (MD092785/MD098626)
OEM Balance Shaft Elimination Kit (Evo)
OEM Master Gasket Set Evo 9 (1000A493)
OEM Master Gasket Set (Evo 9)
OEM Oil Pump (Evo 8) (MD366260)
OEM Oil Strainer (Evo 8/9) (MD343947)
OEM Oil Strainer
Diaqueen OEM gear oil (MZ320345)
Valvoline 20w50 Full synthetic VR1 race oil
NGK Laser Iridium Spark Plugs 7 (ILFR7H)
Diaqueen 75w85 6speed
TRE 6 speed transmission
Megan O2 housing
ETS Intercooler
Grimspeed 3 port boost control solenoid
Megan 3" downpipe
HKS Carbon Ti catback
Megan test pipe
Spark Tech COP
Stock EVO IX turbo
Walbro 255 fuel pump
FIC 780 injectors
ETS Upper Intercooler Pipe
ETS Lower intercooler pipe
ETS intake
Synapse DV/Tomei BOV (have both, willing to use either for tune depending on power/driveability) The Tomei is currently installed due to bucking issues with the Synapse, but the power feels like it is way down now.
The car is currently tuned to 24.5 peak psi. It put down 353whp on a dyno dynamics.
Right now I am looking at either JMS racing, or CBRD.
Does anyone have any suggestions about either of these, or any other possible candidates that would be able to get this issue solved, and get me driving again?
Also, any ideas of what I could check to determine the causes of this problem? Any help is appreciated. I just want a reliable car again.
OEM Oil Strainer
Megan O2 housing
ETS Intercooler
Megan 3" downpipe
Megan test pipe
Spark Tech COP
Stock EVO IX turbo
FIC 780 injectors
ETS intake
Sounds like cylinder one is running lean, and/or having issues with knock.
The injector was my first thought too. They were all pulled, and flow tested. They all came back fine. I don't think the 1st cylinder oil squirter was checked though. I'm not sure if they checked the wiring or not. Even though the injector is fine, the wires going to it may not be, causing it to misfire. I plan on having that checked when it goes back to the shop.
ODUB
Apr 29, 2016 08:07 AM
dupstone
11
Jul 10, 2009 09:01 PM
