Different size fuel pumps on double pumper 255 and 450
So I'm currently running a single Walbro 450 e85 pump. I'm going to modify my pump housing for a double pumper setup and have a 255 kicking around. Is there any issues with running a 255 as a primary pump and the 450 as the secondary pump as far as reliability or supply issues?
If needed I'll buy another 450 but figured since I have a 255 and it should support my flow, I'd ask.
Thanks
Sean
Thanks
Sean
Thanks
Sean
Thanks
Sean
Thank you! I tried searching for others but everything I found was people running the same size. Thought maybe there'd be feed issue into the Y since they're different flow rates but wasn't sure.. Figured I'd save some money if i used my 255 and it'd be easier with my stock fpr. Thanks
420a-t
Apr 11, 2017 07:08 PM
SLVRNBLK
23
Mar 17, 2017 09:52 AM
mxguy1286
Jul 4, 2013 06:10 AM
badev0
13
Jun 20, 2012 10:49 PM
MR.06MR
Jun 30, 2009 02:32 PM
