Evo is dead after an backfire
Old May 18, 2016 | 07:44 PM
Awd_evo's Avatar
Recently I was out driving, coming to an stop sign as I took off got up to 4000rpm with no boost the car backfire super loud causing the car to shut off. To make thing short im getting fuel but no spark , timing is still at tdc , I replace the crankshaft sensor and camshafts sensor with oem but still no spark ??? Could it be a shortage on ground , burn ecu ??? Any help would be appreciated
Old May 19, 2016 | 08:53 AM
b16a95eg's Avatar
Check your 10a IGN fuse under the dash, other than that, It can be your cam or crank sensor
Old May 19, 2016 | 07:35 PM
Awd_evo's Avatar
Thanks got it running was a fuse 10a. But now has an backfire at 2000rpm even after replacing the cams sensor
Old May 20, 2016 | 08:43 PM
b16a95eg's Avatar
It sounds like timing still, unless it's another sensor, any CEL's?
Old May 20, 2016 | 08:46 PM
kaj's Avatar
kaj
An actual backfire, when you let off the gas?
Old May 21, 2016 | 10:13 PM
Awd_evo's Avatar
Yes, timing is still at tdc at camshaft and crankshaft Marking. And yes it's an actual backfire with flame coming out at 2000rpm letting off gas
Old May 22, 2016 | 12:51 AM
LetsGetThisDone's Avatar
That's not back fire. Back fire is actually when the flame goes though the intake tract and blows the air filter off.
What you're experience is raw fuel in the exhaust.
Old May 22, 2016 | 11:35 AM
kaj's Avatar
kaj
I'm curious to know what the problem is because it sounds like a timing issue, but all marks and triggers are spot on, with no CEL.
Old May 22, 2016 | 03:55 PM
Awd_evo's Avatar
Yes, no cel is on. And yes timing is still tdc. I'm having an mechanic friend come over to look at it, I'll have this updated once we find out the issue
Old May 22, 2016 | 04:17 PM
kaj's Avatar
kaj
Good luck, dude! Hope you get it fixed.
Old May 25, 2016 | 04:19 PM
Awd_evo's Avatar
Got it fix and it's an burn ground wire that cause the issue, don't know why or what cause it to burn but Car runs great now.
Old May 25, 2016 | 08:33 PM
ixbreaker's Avatar
Where was the burnt ground wire?
Old May 26, 2016 | 01:27 PM
Awd_evo's Avatar
both ground wire was burn, first one is the ground wire ontop of the intake manifold, 2nd is the ground wire by the camshaft sensor. I replace both of them and added an extra ground wire making an total of 3 ground wire.
Old May 26, 2016 | 01:44 PM
kaj's Avatar
kaj
burned wire? wtf? how in the hell???
Old May 26, 2016 | 02:33 PM
Grounds can burn if they get overloaded, which usually happens when there is poor continuity to the chassis...
RSMike
13
Feb 21, 2011 11:01 AM
CT9A
22
Apr 3, 2006 07:08 PM
LanEvoDemon
Aug 20, 2005 04:50 PM
skibum
Jun 28, 2004 06:07 AM
1QWKEVO
Mar 28, 2004 11:25 PM
