What do I do NEXT?
What do I do NEXT?
Hi evoM people!
I have some questions about my current setup and what it COULD possibly make.
So I have a built 2.0 non-mivec with 8.8 CR and kelford 272 cams. The turbo is a BBK Full with ID1000 injectors and a 255 fuel pump. The car made 400 awhp on 93 octane running 25psi.
I'm curious what kind of I could make by running a little more boost and switching to e85, what injectors I would need, what fuel pump, etc.
I plan to have dual maps for 93 and e85 but i'm not sure what my peak capabilities are. I want to eventually get above 500 awhp but I might need to upgrade this turbo to do that. I don't plan to rev this car past 7500. Probably 7000 to be safe.
Let me know if I left anything important out.
Thanks!
Thanks!
Perhaps upgrading to a walbro 450 E85 pump, rewired, upgrade feed & return.
As for injectors, you might want to go with something that you won't have to worry about upgrading later on if you decide to go with a bigger turbo in the future. I tried the FIC1650 and the driveability on them is really nice for such big injectors. They make me want to switch from my 2150
I thought about 1450's but I might look for some 1650's. And the walbro a450 is a nice pump for sure. I have never rewired one before though. Do you think the feed and return upgrades will be necessary for such a modest power goal?
You can push them to 480-500ish. Depends on the supporting parts.
clash0901 (May 26, 2016)
I'd run a 450 simply because it's easier and cheaper. The double pump hanger is what throws the cost above what i want to spend, plus a double 255 is overkill. Hell the 450 is overkill but doesn't hurt to have a little extra.
And to answer your question seems like the 1450cc injectors should be enough on E85 supporting about 482whp with 80% duty cycle.
http://fuelinjectorclinic.com/hp-calculator
