STM master to slave clutch line install questions
In the process of installing this clutch line:
http://www.streettunedmotorsports.co...r_to_slave.htm
Trying to figure out exactly how it should be installed.
Which end goes to the slave and which end goes to the master? The line fits both ways with both bolts.
Which banjo bolt goes with which side?
Is it designed for you to have to remove the restrictor in the slave? Was going to remove it anyway.
Thanks
Thanks
Ended up installing it this way:
Smaller fitting on master with smaller banjo bolt
Larger fitting on slave with larger banjo bolt
Also removed restrictor in slave
Logically it looks OK this way.
Ill update when I get a response from STM if this is how they install these.
-pal215
wwcagedevo8
Jul 5, 2013 06:19 AM
Gleason at STM
Nov 14, 2012 02:48 PM
selecta
Aug 17, 2012 03:11 PM
Gleason at STM
Evo 'For Sale' Engine Internals and Drivetrain
68
Mar 4, 2012 10:38 AM
ryukinevo
Dec 8, 2010 08:30 AM
