Drop in outside temperature, transmission now feels a lot worse... Really?
It's gotten colder over the past few days and the temperature has dropped in to the 60s/70s. It was 64 degrees on my way to work today.
The transmission never felt great, but now it feels horrible. It's more noticeable before the transmission has had time to warm up, but even when it's warmed up it still feels worse than it was when the temps outside were in the 80s and 90s. Now downshifting into third I'm getting a slight grind which did not happen when the outside temperatures were warmer. Every shift feels like crap.
Is it really possible that this small of a outside temperature change could affect the transmission this much?
Do I need to adjust my clutch as the outside temperature changes?
I was getting used to the bad transmission, but now this is just unbearable.
What exactly do you mean when you say bad transmission? Is your clutch dragging? My clutch was dragging for a good 7 months but the car was definitely drivable. Then one day it just got real bad and started grinding gears out of no where. But alot of people on this forum seem to have experienced alot of different "feels" from different trans fluids. Doubt a fluid would make that significant of a difference though, but it may.
Basically what it feels like is a slight resistance to go into gear, as well as the very faint grind when downshifting into third..
I changed out my underhood and shifter bushings a while ago to WORKS and also wonder if they could be making it worse.
The thing is the transmission never felt great (third gear: either shift at very high RPM or shift extra slow into third), but it's very strange that when the temperatures outside dropped that it got much worse.
My trans is always a bit more notchy when it gets cold out.
I was running the redline cocktail and I didn't like it at all. The diaqueen actually feels better to me.
You know I've never been able to determine if my clutch is actually dragging. I don't have evoscan and I don't have a cable so I can't turn off my launch control to try the Jack's transmission test.
But always eliminate any possibilities that don't involve dropping the trans first. Check fluid level, bleed the clutch system, ensure no components are bent or loose Yada Yada.
again though, sounds like you want to adjust the clutch engagement upwards first and see how that helps. I'm mechanically challenged and it's a piece of cake, there's a how to on the forum. just need a 12mm.
didn't mean the cocktail, I just run regular redline trans, but I'd look at clutch engagement first. it should be awkwardly high
Ralli_Red
15
Mar 2, 2016 09:59 AM
Toxin
Sep 9, 2013 08:31 AM
spyderx
16
Sep 20, 2004 04:22 PM
