Evo 8 oil squirters hitting Wiseco pistons?
I did a search and found that its an issue on evo 10s and also 8/9s with stroker setups but the car I'm working on is a stock 2.0 evo 8 with wiseco 9:1 pistons and manley rods being installed. The pistons hit the oil squirters / won't even get close to going down all the way. ( 1/4" or so from being down all the way ) Does anyone have pictures on how to bend them to avoid me cracking them or having clearance issues with the crank then? Any advice would be appreciated.
Which way are you trying to actually move the squirter though, does it just get bent down slightly or does it also get bent towards the front or back of the car? I'm sure its pretty simple once you see what actually needs to be done but my engine is in the car so I'm fighting oil dripping on me too haha.
I had to bend mine down and out a little bit.. I have read this makes them weak and they will likely break off at some point.. Im just crossing my fingers they settle nicely in the bottom of the pan.
Only reason I didn't delete them was to keep my oil pressure from being sky high.
Would it work if you install thicker gasket or a extra gasket between the blosck and squiter, so it mounts slightly further from the block and give you slight more gap between the piston and squiter? Just throwing out an opinion.. If you are going to try, careful not to block the oil feeder hole on the squiter bolt.
bsphillips
19
Sep 23, 2016 08:06 AM
djikonatx
44
Aug 30, 2011 07:56 PM
elhalisf
13
Oct 22, 2010 09:49 PM
