Do i need a retune or is there something else wrong?
#46
Regardless of what they do (they enrich WOT), you're trying to fix a problem, whilst leaving another problem untouched. Your car has a vacuum leak at idle. Which is skewing fuel trims. And depending on the tuner could be playing with WOT fueling.
You're diagnosing an issue. You should be fixing problems as they arise. Not finding a problem and then saying, "oh that won't cause the present issue," and then proceeding to something else.
#47
Just throwing this out there, but since this all happened when you swapped your intake. Might be a good idea to try throwing some electronics parts wash on the maf (connector pins) and harness pins to clean them up and plug them back in. Electrical gremlins are a *****. Also inspect the harness to make sure the wires all look in good shape and that the plug is fully seated in the MAF when your done.
#50
maybe check your injectors for the infamous black gunk, have you been only using e85 for a long period? do they change blends for winter where you are? either could cause running lean and then detination . going wot in the 13s is not a good thing
#52
the car was having an un-related (i think?) bogging issue (another thread for that).. ran 12.6 @ 120mph. Was bogging for a split second at the bottom of 2nd, 3rd, 4th gear.
#53
it wouldnt hurt to check your injectors again just incase, I had a set of precision 1000s gum up in just a couple months, that was a long time ago. ive been afraid to use e85 ever since
#56
#58
Well took UICP off and checked every possible hose that I could. Had my entire arm under the intake mani just checking all of the EGR hoses, etc etc etc.. Found absolutely nothing. Checked little things like the MAF adapter gasket, etc. All good.
Since the injectors tested and flowed good, can rule that out.
Since the AFRs are perfect when cruising / idling, and only go lean under load... that, to me, points to fuel delivery... does it not? Wouldn't that make sense?
I'm thinking it may be a clogged / bad FPR?
Or could be something related to the fuel pump rewire my tuner did a while back... even though it ran perfect for over a month.
#60
Wanted to update car is finally 100% back to normal.
Took it back to tuner and he said there were several boost leaks (we couldn't find the first time I guess?) and a couple leaks around the EGR (thought I looked that over pretty good?)
But nonetheless the car made great power and I'm a happy camper.
Thanks for all of the help
crnesst
Jun 16, 2004 05:33 PM
